It is currently Sun Nov 02, 2025 9:37 pm
 Post subject: Mitsubishi magna?!
PostPosted: Tue Oct 11, 2011 2:57 pm
Has any body used a Mitsubishi magna fwd flywheel and clutch set up on a km210 tranny? I'm hoping it's possible because it's the only flywheel I have found in nz that would maybe fit the 225 mm clutch set up
 Post subject: Re: Mitsubishi magna?!
PostPosted: Tue Oct 11, 2011 6:19 pm
We didn't get the Magna over here, but it's got the 2.6 in it I think. I know the intake bolts on the 2.6 in the starion... So Id guess it wouldn't. Purely a guess though.
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Tue Oct 11, 2011 6:48 pm
What do you mean by intake bolts man? its all bolted up, my only worry is that its large enough to engauge with the starter
PostPosted: Tue Oct 11, 2011 8:51 pm
I was purely guessing that being that the flywheel is from a 2.6 engine, of the Astron engine family, that it probably wouldn't work correctly with the 1.6 or 2.0 engines from the Sirrus family. As there really isn't much that I'm aware of being interchangeable on the two engines themselves. They are (usually) even a different bell housing pattern (narrow and wide block). If it bolts up, and clears the bell housing I'd say your 90% of the way to making it work.
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Wed Oct 12, 2011 10:16 am
Now hopefully his starter plate and starter are a good match.
PostPosted: Wed Oct 12, 2011 11:53 pm
will a km200 off the 4g15 engine fit without any modification? I pulled one out at a junk yard, but I didnt notice untill it was pulled that the clutch folk engaugement system is alot different, I also noticed the clutch is smaller.
