http://www.4g61t.org/forum/
Lowering options
http://www.4g61t.org/forum/viewtopic.php?f=22&t=35182
Page 1 of 1
Author:  twokss [ Tue Aug 16, 2011 6:03 pm ]
Post subject:  Lowering options
I've read a few posts about using Dsm suspension to lower our cars but Im a little confused. I put expo spindles and brakes in the front of my sedan and it threw the camber way off and lifted the front end about an inch and a half. Could some one explain the process a little better and tell what parts are needed. Thanks
Author:  Mechacode [ Tue Aug 16, 2011 7:53 pm ]
Post subject:  Re: Lowering options
The easiest imo, and cheapest by buying used parts ("worn out" on a dsm is just right on a car that's nearly a thousand pounds lighter) is by buying AWD dsm agx's for the front with dsm lowering springs on them (or buy them separate, only need the front) and then AWD dsm GR2's (mod the mounting hole, either weld on another hole or bore out the original) on the back with STOCK awd dsm rear springs. This will give you around a 2" drop all around and it'll stiffen things up quite a bit.
You will have to take the upper mounting plates off your stock strut assembly and transfer them over to the dsm bits.
My costs (yours may differ):
$175 Used awd dsm AGX's with lowering springs already on them
$40 for a set of stock awd dsm springs (only used the rears)
$60 rear awd dsm GR2's already modded (from 89mirageman) for csm use.
=$275 for a "sport" suspension/2" drop
If the captain will chime in, he can tell you about his efforts with an ebay coilover setup.
Author:  twokss [ Tue Aug 16, 2011 8:15 pm ]
Is there a reason for needing agxs in the front? And the mounting hole in
The rear I assume it the one on the bottom of the strut?
Author:  Mechacode [ Tue Aug 16, 2011 8:51 pm ]
No specific need for agx's, any aftermarket (preferred) awd dsm front strut should work. Yes, the bottom mounting hole.
Here are Captain's writeups,
Using awd dsm struts with stock awd springs in the front and csm rear springs, dsm lowering springs up front and awd stock springs in the rear provide the 2" drop:
http://www.4g61t.org/forum/viewtopic.php?f=10&t=26736
Ebay coilovers:
http://www.4g61t.org/forum/viewtopic.php?f=10&t=28497
I *think* he tossed the coilovers and went back to the awd dsm bits.
https://www.phpbb.com/
