It is currently Thu Oct 23, 2025 2:57 pm
PostPosted: Fri Feb 18, 2011 3:25 am
I want to add cruise control to my 89 Colt GT. I thought about using the entire CC setup from a 1g DSM to include the switch assy on the steering stalk. I'm hoping as a side benefit that the 5-way intermittent wiper function will work as well since the Colt only has a single intermittent wiper function.
PostPosted: Fri Feb 18, 2011 8:11 am
It's not a bolt in if thats what your asking...
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Fri Feb 18, 2011 8:37 am
Nate is spot on. Will definitely require a bit of enginuity to make it work. Thankfully you can pull all the necessary wiring diagrams from lilevo's site. If you are up to the challenge of adding the required wiring and relays I see no reason why it would not work.
