It is currently Thu Oct 23, 2025 12:39 am
 Post subject: bad relay?
PostPosted: Tue Feb 08, 2011 3:45 pm
Ok,so ive searched and searched and cant find this exact problem. I have a 89 colt I bought for $300 in sep. runs good so far I put 4,000 miles on it. so here is the problem someone put a push button starter on it and some times it don't start, it sounds like the relay is sticking where the button wires are going to. If I roll start it it will start except when its icey outside. Then after this sometimes it will start with the button. This only used to happen like twice a week now its is happening more often. Any ideas could it be the relay think the starter is sticking? I need to figure this out so I can drive it for the rest of winter, until I can do the swap this summer :supz:
Thanks for reading my post any ideas?
 Post subject: Re: bad relay?
PostPosted: Tue Feb 08, 2011 5:40 pm
damn i paid 300 for mine also..with a rod knock.. been running almost 2 years now..and only have 3800 miles on it.. u drive too much lol....
I would get a diff push button switch and try that.. they have a problem with going out alot.. its probably a cheap one and there not made for alot of use..
PostPosted: Tue Feb 08, 2011 5:57 pm
Steve[/quote]
Yep I get around lol, I'll try a new push button but it sounds like it is still engaging because you'll still hear a buzzing sound like the relay is stuck or something but it wont turn over.
Jacob
PostPosted: Sun Feb 13, 2011 9:08 pm
It was my starter back up and running, thanks for all the help or lack there of,
