It is currently Mon Oct 20, 2025 8:43 pm
PostPosted: Mon Jan 24, 2011 12:25 pm
I just got the tranny and realized that my clutch was not disengaging. I had alot of play in the pedal and thought it needed adjustment. Then I thought that maybe we didn't bleed the clutch properly. So I notice my pedal isn't level with the brake pedal. After further investigation I come to find out that you can pretty much twist my pedal with your hand. I look up under the dash and notice that a section of the bracket is broken. The part that's broken is on the metal that turned brown right between the brake and clutch pedal.
So my question is do I have to replace the whole pedal assembly or can I just replace the bracket/clutch pedal? Are the accelerator and brake a single unit?
George
1997 Nissan 240sx
1970 Datsun 240z
PostPosted: Mon Jan 24, 2011 1:35 pm
The clutch pedal assembly is separate on these cars although it does rest on the end of the brake pedal.
PostPosted: Mon Jan 24, 2011 1:46 pm
Have you had any experience welding it? To much understanding, it'd make the material weaker.
George
1997 Nissan 240sx
1970 Datsun 240z
PostPosted: Mon Jan 24, 2011 2:39 pm
I sure as hell wouldn't weld it. Buy another pedal assembly from a 5spd car, they should all be the same.
