Ok, so ive been scouting around lately for a good CSM, Starion, Mighty max to do either a 6G72 DOHC Motor swap or A 4g63T swap into and i stumbled across a real gem. I happened to find a 93 dodge colt base model that had been bought BRAND NEW from the dealership in 93 by a company that converts cars to electric. The car was converted to electric brand new with literally ZERO miles on it. Fast forward to today, i called a friend and he happened to be getting rid of a few cars and mentioned a dodge colt. My ears perked up and went down to check it out..
Come to find out.... the car has 1200 miles on it.... yes you read that right, 1200 miles on it. The electric conversion since has failed and all the stuff was yankd out of it and it was a rolling chassis with pretty GREAT paint, but the door panel tops are faded and crusting and the rear seats are totally shot and split open as is the drivers seat. the dash and shifter boot and radio and all plastics are in PERFECT shape (look brand new). The spare trunk well was cut out and had an aluminum pan fabbed up and installed in place to hold batteries. The gas tank, exhaust and ac lines and heat and engine harness are all gone as is the clutch pedal it looks like (car is 5spd cable clutch). i havn't had a chance to look under the dash to really see what the deal is. The rear springs have "helper springs" installed inside to deal with the added load of the batteries tha were in the trunk (awesome for drag racing to keep the rear end from sagging under launches). Anyway its an awesome setup and its perfect for a 4g63 race car once i use a hair dryer to remove all the gay "electric powered" vinyl stickers off of the body. Best part..... i got it for trade for an aem FIC unit (worth about 300 bucks). title is clean and legit
hopefully ill get pics up soon.
Anyway, to the Questions.... The car is a 5 spd cable clutch.... im wanting to convert to a hydaulic setup from a dsm probably...
are there indentations on the firewall for the clutch master cylinder?? if so do i just have to drill the holes and use a holesaw to cut the middle hole so i can bolt on the clutch master cyl?
Also whats the weight of this car??? this seems to be the base model (crank windows, single side mirror, basic radio)
Also since there is no front sway bar can i just get the control arms and swaybar setup from an automatic 93-96 csm and bolt it on??
Last an final question, what do you guys think of a single turbo 6G72 DOHC setup??? i did some measurments on an N/A dohc 6g72 and the 93 colt chassis, and it should BARELY fit, but im not sure about the weight of the 6g72 dohc longblock vs a 4g63 longblock. ive heard they are very close in weight oddly enough from alot of people.... obvioulsy if the motor weighs more it will help as its over the front wheels, but what are your thoughts??? The car will probably only be used for drag racing as most of the factory wiring has already been removed (engine harness, body harness in engine bay) by previous owners.
