It is currently Sat Nov 01, 2025 11:55 pm
 Post subject: Kyb AGX Struts
PostPosted: Tue May 04, 2010 6:22 pm
would these work on a csm?....or are they car specific?
http://www.galantvr4.org/ubbthreads/sho ... =0&fpart=1
1991 Plymouth Colt - Project
 Post subject: Re: Kyb AGX Struts
PostPosted: Tue May 04, 2010 6:30 pm
They are car specific. They will not bolt directly on to a CSM. KYB does not make AGX's for a CSM, just GR2's.
PostPosted: Tue May 04, 2010 6:36 pm
Thanks
PostPosted: Tue May 04, 2010 9:54 pm
If your looking for some struts for your csm
I will be having some up for sale soon
Front struts with springs
Rear struts with ground control coilovers
91 Talon (Full Drag Car)
PostPosted: Wed May 05, 2010 2:49 pm
Front KYB AGXs for 1G AWDs (and theoretically FWDs) work on CSMs. No such luck on the rears though.
1989 Mirage Turbo w/4G63T
1991 Mazda MX-5 (UK spec)
2018 Hyundai I30N
PostPosted: Wed May 05, 2010 3:31 pm
1g FWD and AWD and GVR4 struts are the same in the front. As for them working on a CSM, they will bolt up, but they're not an exact match. It will change the ride height of the car, most likely raise it up.
PostPosted: Wed May 05, 2010 9:56 pm
The fronts work perfectly. If they do alter the height, it can't be by much. The rears on the other hand, make the back of the car look DUMPED.
I have 1G AWD AGXs on the front of my car, and for like 5 minutes, I had them on the back as well. The rear of the car was too low, so I swapped them out for GR2s made for the CSM. But front 1G AWD shocks are a direct bolt on to our cars.
Both pics have the same springs on the car (Tenzo-R GF2s for a 1G AWD)
My car with 1G AWD AGXs up front and CSM GR2s in the rear:
My car with 1G AWD AGXs front and rear:
2018 Hyundai I30N
PostPosted: Tue May 18, 2010 8:34 pm
Do you happen to have part numbers that you used. Great job on this btw!!!
Chuck Norris can sneeze with his eye's open!
Chuck Norris can slam revolving doors!
Boosting to a neighborhood near you
http://www.turboelements.com
