It is currently Fri Oct 24, 2025 8:19 pm
 Post subject: Steering Wheel Options?
PostPosted: Wed Jan 13, 2010 10:49 pm
What is a good steering wheel for a 89 GT steering column? I'd really like to get an aftermarket wheel and I don't know what the best diameter is and where to find it. What is the diameter of the stock wheel? I don't want one of those garbage Ebay ones either.
PostPosted: Wed Jan 13, 2010 11:09 pm
I was always under the impression that the aftermarket dsm hubs would only fit the na csm steering columns. I do remember someone posting that it was fairly easy to mod the turbo column for an aftermarket hub though.
I had a 365mm Momo on my 4g and loved it.
Here is an Evo 8 wheel that I made a hub for.
PostPosted: Sun May 12, 2013 7:14 am
Back from this 2010 thread ;)
I'm looking for an EVO8 wheel swap like this.
I keep the stock C53 telescopic column.
Airbag removed.
And using this method i think : http://www.dsmtuners.com/forums/article ... l-dsm.html
@ Chris: Have you use this method or similar ?
Horn bouton working or it need to be customised ?
An DSM hub adapter whill fit ?
Thanks.
Remy
