It is currently Sat Nov 01, 2025 4:27 am
PostPosted: Wed Jul 08, 2009 10:15 am
I'm wanting to replace the radiator in my Mirage as I simply cannot get it to stop leaking at the upper hose inlet. Hell I've replaced evrything else :vom: :rolleyes:
I'm looking at a Mishimoto Aluminum radiator for a 90-94 Eclipse. Will this fit in my 89 Mirage? Of course there are no listings for an 89 Mirage.
PostPosted: Wed Jul 08, 2009 10:28 am
An Eclipse radiator will not be a direct bolt-on. Eclipses have their radiator cap on the thermostat housing, not the radiator, plus the dimensions are a bit different. You can use a radiator out of any 89-93 Mitsubishi Galant, and I think 94-98 Galants as well.
PostPosted: Wed Jul 08, 2009 10:30 am
Anything for a dsm you will need to change your thermo housing top. Look for one for a galant vr4, only thing different is the way the little nub goes for the overflow.
PostPosted: Wed Jul 08, 2009 10:32 am
I've got a stock (plastic/aluminum) 90-93 Accord radiator in mine, the size was perfect, but I had to weld the lower mounts into a different spot. For the upper mounts, it was just a matter of ovaling the holes on the two little brackets where it bolts to the upper core support. They needed to be a quarter inch further back because the radiator is a little thicker; other than that, the upper mounting points lined up perfectly.
PostPosted: Wed Jul 08, 2009 11:39 am
Thanks for the quick replys. I really don't have a way to perform welding and custom fits. I just had some custom upper brackets made for my stock radiator as the stock ones were worn.
It doesn't look like I'll be able to find a good radiator for my Mirage Turbo. The last 2 turned out to be garbage.
This car is amazingly difficult to find parts for...
Is there a reason to buy a Galant VR4 radiator over a stock Mirage Turbo unit?
PostPosted: Wed Jul 08, 2009 12:04 pm
The Galant radiator is probably easier to find, but they're basically the same thing. Also, the radiator doesn't have to be from a Galant VR4, it can be from any model Galant, all the same shit.
PostPosted: Wed Jul 08, 2009 3:53 pm
I vote for the ebay honda radiator. Less than $100 shipped, half the size, works perfect (as long as you get the thick one and have a 1000cfm+ fan on it). Only downside is that it doesn't look stock unless you paint the top tank black. Would have to redrill+tap two holes for the upper mount, mine fits on the bottom mount.
PostPosted: Wed Jul 08, 2009 6:07 pm
For what model would I look for? Lot's of Honda's in the world :-?
I just bought a fan but I remember it being 600cfm :( Could be wrong about that.
Nothing else is looking stock under that engine bay. No compromises on reliability. That's my #1 goal :wink:
GPI will build me a radiator for about $120. It's a Galant type for which I would have to cap a few ports but fit should be correct. A strong downside is that it takes about 2 weeks to build.
PostPosted: Wed Jul 08, 2009 7:10 pm
http://cgi.ebay.com/ebaymotors/Honda-Ci ... ccessories
That's the one I bought.
Here's a fan that will work with it.
http://cgi.ebay.com/ebaymotors/12-RADIA ... |72%3A1171
PostPosted: Thu Jul 09, 2009 10:19 am
That looks OK but then there's modification I don't want to perform. I'm trying like hell not to add holes or alter this vehicle IF I DON'T HAVE TOO. That being said I've altered the shit out of this car like battery in the trunk, on and on.. I don't know, smaller radiator.. it'd play on my mind - or what's left of it :rolleyes:
What about this?
http://cgi.ebay.com/ebaymotors/87-92-al ... otohosting
PostPosted: Thu Jul 09, 2009 10:23 am
Dude, don't fruit and banana around with a Honda radiator. If you ask me, that's something that you do out of desperation because you don't have any room for your turbo and/or intercooler setup. Your car is mostly stock and all original. Just find yourself a Galant radiator and be done with it, I bet your local auto parts store has one in stock, or could have one ordered up for you very easily.
You can also try this site:
http://www.radiatorbarn.com
i believe these are direct radiator replacements also, one of the member here has this radiator and he said its direct fit
http://cgi.ebay.com/ebaymotors/aluminum ... C72%3A1171
PostPosted: Thu Jul 09, 2009 11:42 am
Hong Kong location. I'm hopeful to find one closer to California. Imagine that I finally have my Mirage running well after 3.5 years and now I can't drive it because the radiator leaks like a sieve :(
No one commented on my EBAY find. What, you don't like it? It's a Galant Aluminum radiator.
PostPosted: Thu Jul 09, 2009 11:46 am
Here are the specs on the EBAY Aluminum radiator:
Specifications
Vehicle Notes: Manual Transmission.
Core Size (in) approx: H375mm×W658mm×T50mm(H14-3/4"×W25-7/8"×T2" - 2 Rows
Overall size(in) approx: H463mm×W670mm×T60mm(H18-1/4"×W26-3/8"×T2-3/8")
Inlet/Outlet: Φ 35mm/Φ35mm( Φ1-1/2"/Φ1-1/2" )
Core and Tank: ALL ALUMINUM
Weight (lbs) approx: 14
Vehicle Fits
MITSUBISHI GALANT
l VR-4 E38A/E39A CHASSIS 2.0L 4G63T TURBO L4 ENGINE 1987-1992
l LS/GS/GSR/GSX/ES/S 2.0L 4G63 L4 ENGINE 1987-1992
PostPosted: Thu Jul 09, 2009 12:12 pm
I'm sure that would work fine.
