| re: differatial lsd or not? http://www.4g61t.org/forum/viewtopic.php?f=22&t=29569 |
Page 1 of 2 |
| Author: | wcassar [ Fri Jun 05, 2009 2:27 pm ] |
| Post subject: | re: differatial lsd or not? |
Hi I have an AWD gearbox of 95-99 4g63turbo. Is the gearbox with a front LSD or not? |
| Author: | CaptainTonus [ Fri Jun 05, 2009 3:16 pm ] |
| Post subject: | Re: re: differatial lsd or not? |
Quote: Hi I have an AWD gearbox of 95-99 4g63turbo. Is the gearbox with a front LSD or not?
No. The front diff is not an LSD. The center diff is an LSD, but that will not be useful for a FWD application.
| Author: | wcassar [ Fri Jun 05, 2009 3:32 pm ] |
I have locked the viscous coupling unit to have a permanent AWD. I m using only the front application. |
| Author: | wcassar [ Sun Jun 07, 2009 7:00 am ] |
any ideas of how to make more grip? |
| Author: | CaptainTonus [ Sun Jun 07, 2009 1:00 pm ] |
Quote: any ideas of how to make more grip?
Racing slicks.With an LSD you'll just spin the shit out of both tires instead of one. |
| Author: | wcassar [ Sun Jun 07, 2009 11:59 pm ] |
But racing slicks are not good for road usage? water etc!! |
| Author: | 92 TSi AWD [ Mon Jun 08, 2009 12:09 am ] |
Wheel spin on any higher HP, lightweight FWD vehicle is inevitable. Theres not really any way to avoid it (besides doing the AWD swap) but there are a few ways to make it not as bad. Wide racing slicks would probably be your best bet.
| Author: | wcassar [ Tue Jun 09, 2009 10:18 am ] |
I have 16" rims with 195 / 45 / 16 tyres. What is the maximum that my car can handle regarding the thickness? |
| Author: | CaptainTonus [ Tue Jun 09, 2009 10:21 am ] |
Quote: I have 16" rims with 195 / 45 / 16 tyres.
225/50 or 225/45 should fit depending on the offset and width of your wheels. 195 is pretty skinny.
| Author: | wcassar [ Tue Jun 09, 2009 6:59 pm ] |
Ok I will go for the 225/50 to have more wall of tyre too. thanks for the info |
| Author: | wcassar [ Wed Jun 24, 2009 12:38 pm ] |
I made wide slicks and the first reaction were the axles. I broke the driver side |
| Author: | Mechacode [ Wed Jun 24, 2009 3:43 pm ] |
Ouch. That's usually what happens. If you're making a lot of power, you should buy custom pieces that are thicker than stock. If you broke an original axle, just get pair of new ones for each side because you'll break the other one right after you put in the new one on the other side due to them being worn out after nearly 20 years. |
| Author: | wcassar [ Wed Jun 24, 2009 7:03 pm ] |
Are there any stronger shafts? any site? |
| Author: | CaptainTonus [ Wed Jun 24, 2009 9:19 pm ] |
Quote: Are there any stronger shafts? any site?
No. You'd have to have them custom made. Very expensive.
| Author: | wcassar [ Wed Jun 24, 2009 10:11 pm ] |
I would like to do them custom made. From were can I have a quotation for them? regards |
| Page 1 of 2 | All times are UTC-05:00 |
