Yep, use the early FWD diff or any AWD diff. Just swap over your ring gear to the new diff and reshim it and you're done. I believe the 2g tranny will work in the 4g's however I don't know if you use the tranny mounts from the dsm or the Mirage. You can use a 1g tranny as well but you'll have to fabricate rollstops. I guess if you're converting to AWD this will have to be done anyway though.
_________________ 93 Mitsubishi Expo LRV 1.8/manual
