It is currently Mon Nov 03, 2025 2:13 am
 Post subject: DSM oil cooler install
PostPosted: Tue Mar 13, 2007 9:50 am
Im trying to find some info on this, Does anybody have a full 90 setup with the stock lines? Any pics info?
PostPosted: Tue Mar 13, 2007 11:12 am
Its all a bolt on, only part most people overlook is the thermostat housing has one less water inlet on it on a 90 model. Just make sure to either plug it or get the correct housing (90 or an NT housing should suffice.) Other than that you will have to do a little fab work on mounting it. I used some angle aluminum when I fabbed the brackets for my 92 talon.
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
