http://www.4g61t.org/forum/
JDM Cyclone ECU Question
http://www.4g61t.org/forum/viewtopic.php?f=22&t=20655
Page 1 of 1
Author:  Malac0da13 [ Thu Mar 08, 2007 8:40 pm ]
Post subject:  JDM Cyclone ECU Question
I just got a JDM Cyclone motor. The number on the ECU says its from the 87-89 GVR4. The thing is the wiring harness is cut. Can I use a wiring harness from any 1G DSM?
Author:  89coltgt [ Fri Mar 09, 2007 2:57 am ]
Yes, but some of the sensors may be different, depending on what year harness you use, and I am not sure if the pins on the cyclone ecu correspond with the usdm harness.
Author:  Malac0da13 [ Fri Mar 09, 2007 8:10 am ]
Thats kind of what i figured. Any idea where to find a pin out for the GVR4 ECU? If i could get the harness from a 90 would i needa swap sensors? And what about the cyclone intake?
Author:  Flying Eagle [ Fri Mar 09, 2007 9:07 am ]
www.galantvr4.org
https://www.phpbb.com/
