Its all a bolt on, only part most people overlook is the thermostat housing has one less water inlet on it on a 90 model. Just make sure to either plug it or get the correct housing (90 or an NT housing should suffice.) Other than that you will have to do a little fab work on mounting it. I used some angle aluminum when I fabbed the brackets for my 92 talon.
_________________ 49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
