| Can I shove it? http://www.4g61t.org/forum/viewtopic.php?f=22&t=20569 |
| Author: | Phlipfreq [ Fri Mar 02, 2007 4:46 pm ] |
| Post subject: | Can I shove it? |
245/35/17 9" width 20mm offset |
| Author: | CaptainTonus [ Fri Mar 02, 2007 5:02 pm ] |
| Post subject: | Re: Can I shove it? |
Quote: 245/35/17 9" width 20mm offset
Maybe if you had an EVO. I'd pay money to see it on a CSM.
| Author: | Flying Eagle [ Fri Mar 02, 2007 9:07 pm ] |
| Post subject: | |
.... or if he had the widebody style fenders like the Jackie Chan Cup car at the top of every page! |
| Author: | Phlipfreq [ Sat Mar 03, 2007 7:43 am ] |
| Post subject: | |
I just want to stop plowing through the corners |
| Author: | CVD [ Sat Mar 03, 2007 9:18 am ] |
| Post subject: | |
9" wide wheels will cause bigger problems than understeer on a Colt if you're trying to make it handle. If you want to stop plowing through corners get sticky tires and learn how to manage your cars weight shift - i.e. turn in delicately at first so you dont overwhelm the front corner. |
| Author: | CaptainTonus [ Sat Mar 03, 2007 11:32 am ] |
| Post subject: | |
Quote: I just want to stop plowing through the corners
Yeah, what CVD said. Bigger tires won't really help your situation. You have a FWD car, it will always plow until you address more of your suspension. There is such a thing as too much tire for a car. |
| Author: | Phlipfreq [ Sun Mar 04, 2007 12:37 am ] |
| Post subject: | At least I can go really fast in a straight line |
Forget it I'm officially done with this car |
