| Offline |
| The Silent Administrator |
If you really wanted to make this easier the second time around, you can remove a circular panel of metal on the floor pan to accomodate the pump going in and out without removing the tank the next time. Just be sure to seal up the plate with window weld or seam sealer so noise and rust don't creep in too quickly. But yes the tank is 4 nuts, drop it with low fluid inside, alot of tanks have the drain bolt 12mm head. Just make sure you don't break any lines while lowering the tank.
