So I found a 1990 Galant Auto with silver metallic oil. The engine runs until it gets hot, then it locks up. I can probably pick this thing up for *super* cheap.
The good news? It has a sohc
That means my 1.5L should bolt right in and be nearly a plug and play affair.
Is there anything I should know about that might not work out sticking the 1.5L into the Galant? Wiring harness should be nearly identical.
power to weight wont be on the sluggish side? that more than likely is an old gen 4g93 model engine? 1.8 SOHC? they also came in some of the Expos (or Chariots or RVR shaped vehicles).
they're pretty good for torque etc and have similar properties to the 4g15 as u are discovering.
i think that car wont move too well and some sucky gas consumption figures (smaller engine pulling heavier vehicle).
we got our JDM Galants (from that era) with 3 engine combos:
4g67 (1800 DOHC/ auto or manual)
4g63 (2000 DOHC/auto or manual)
4g93 (1800 SOHC/auto)
nothing smaller....
for info purposes, we also get:
4g93 GDI (1800 DOHC/auto)
4g94 GDI (2000 DOHC/auto)
these are the new model motors.
