| Swaybar Upgrade Anyone? http://www.4g61t.org/forum/viewtopic.php?f=22&t=19784 |
Page 1 of 2 |
| Author: | Bill Spruill [ Wed Dec 20, 2006 6:26 pm ] |
| Post subject: | Swaybar Upgrade Anyone? |
Hi. Has anyone upgraded their swaybar(err, ANTIsway bar)? I have my motor out in anticipation of an AWD conversion. I know that the current bar should fit very well. But should/could I upgrade the bar? Push to shove, I can go to a machine shop and have the current bar reproduced with a larger diameter steel, but is there an after market job that I can use? What are the problems? Should I make urethane bushings, or are these available, too? Thanks for advise. (Yes , I am going to do a search now; no, I forgot to do that before I wrote this, sorry. |
| Author: | CaptainTonus [ Wed Dec 20, 2006 7:15 pm ] |
| Post subject: | |
Couldn't you just use an upgrade rear sway bar for a 1g AWD? Those are easy to get ahold of. Suspension Techniques makes a 1" rear sway bar that comes with urethane bushings, I think RRE sells it for $160. It's a very nice piece, I have one on my 1g AWD. |
| Author: | t2fastalon [ Wed Dec 20, 2006 7:28 pm ] |
| Post subject: | |
I have a upgraded rear sway bar! but couldn't tell you what kind. It was on the car when I bought it |
| Author: | Mechacode [ Wed Dec 20, 2006 7:56 pm ] |
| Post subject: | |
Other than the turbo sway bar (which I assume you have), I don't know of anything else that will fit. |
| Author: | t2fastalon [ Wed Dec 20, 2006 8:10 pm ] |
| Post subject: | |
In no way is mine stock! I will take pics tomorrow in the daylight. 2 people on the here have own this car also. maybe they can shed some light on it..Briggs and Antilag200 |
| Author: | netninja2001 [ Wed Dec 20, 2006 9:05 pm ] |
| Post subject: | |
CaptainTonus and t2fastalon - i'm pretty sure he meant the front swaybar bill - sorry, i don't know of any other bars that would work. the option you said seems to be the only way at the moment. |
| Author: | Bill Spruill [ Wed Dec 20, 2006 10:20 pm ] |
| Post subject: | |
Well, That sure leaves things open to try. I'll have to get an AWD one to check differences. Thanks. |
| Author: | ScottSpecV [ Thu Dec 21, 2006 8:43 am ] |
| Post subject: | |
I seem to remember hearing that the 1G FWD one works in the rear. For the front, the 1G AWD one should work. |
| Author: | Crackerman [ Fri Dec 29, 2006 12:06 am ] |
| Post subject: | |
he's going for awd. its recommended that the fwd cars don't install a rear sway bar, as it can make the car snap oversteer and makes it unpredicatable while driving at 10/10ths. as far as an awd converted csm gor for the huge rear sway bar, you will kave that extra oomph pushing you around, and it will allow you to 4 wheel drift through the corners, instead of understeer. |
| Author: | Bill Spruill [ Fri Dec 29, 2006 11:12 am ] |
| Post subject: | |
as far as an awd converted csm go for the huge rear sway bar, you will have that extra oomph pushing you around, and it will allow you to 4 wheel drift through the corners, instead of understeer. Ah! That sounds interesting, but what do you mean by the "huge" rear antisway bar? Model or part number? Dealer or aftermarket? |
| Author: | MR HYDE [ Fri Dec 29, 2006 12:29 pm ] |
| Post subject: | |
Bill, go with an RM racing rear swaybar, and poly bushings. Mach V sells the rear bar for 175.00. http://machv.com/newrmracsway.html G- Quote: Quote:
| Author: | Crackerman [ Fri Dec 29, 2006 1:40 pm ] |
| Post subject: | |
Quote: Quote:
as far as an awd converted csm go for the huge rear sway bar, you will have that extra oomph pushing you around, and it will allow you to 4 wheel drift through the corners, instead of understeer. Ah! That sounds interesting, but what do you mean by the "huge" rear antisway bar? Model or part number? Dealer or aftermarket? ^^^ that one |
| Author: | Bill Spruill [ Fri Dec 29, 2006 5:16 pm ] |
| Post subject: | |
| Author: | maags2007 [ Mon Feb 26, 2007 8:09 pm ] |
| Post subject: | |
no updates? did you find out what will work in the front? |
| Author: | xlr8 [ Mon Feb 26, 2007 9:17 pm ] |
| Post subject: | |
FYI upgraded swaybars on FWD are great so long as your not a pussy and can handle some opposite lock. My turbo Excel has upgraded front and rear bars and exhibits very nicely controlled "lift-off" oversteer. If it steers too much you just give it some more juice which understeers the front and corrects the action. |
| Page 1 of 2 | All times are UTC-05:00 |
