It is currently Wed May 22, 2024 9:19 pm
 Post subject: Seatbelts not working
PostPosted: Mon Jan 18, 2016 2:37 pm
Has anyone had any problems with their automatic seat belts? Mine stopped working a few days ago, I checked all fuses related and none were blown. What else would cause both seat belts to no longer operate? Car is a 1989 Mirage GT
PostPosted: Mon Jan 18, 2016 5:37 pm
there is a small silver box located in the center console just in front of the rear ashtray.. u need to remove the whole console to get to it..it might have came unplugged or just went bad.
PostPosted: Tue Jan 19, 2016 1:58 pm
I have the same issue in my car, still need to swap that module as I've gone through everything else like you have.
PostPosted: Tue Jan 19, 2016 9:16 pm
Where would I find another module? Would one from a 1g tel work?
PostPosted: Tue Jan 19, 2016 9:49 pm
If someone takes a module to a TV/circuit/stereo repair place, there might be a chance of finding a common failure point with these modules. Caps and ISC/injector drivers on ECM's, so why not some simple output failure or switching issue? Can't be much logic to the little box. Wish there was a circuit diagram for them, much like old stereo boards and TV circuit boards. Specs help even more ....
PostPosted: Sat Jan 23, 2016 11:10 am
Maybe I will take the module apart and see if any things on it is burnt. Or convert to manual seat belt.
PostPosted: Mon Feb 01, 2016 8:18 am
Found a vid on YT.
Click me
Maybe it relates. Haven't watched it yet.
PostPosted: Mon Feb 01, 2016 7:36 pm
Thanks, I'll watch it when I get home.
PostPosted: Tue Feb 02, 2016 12:04 pm
One of our members posted pics of a burnt circuit board on FB.
Best to open the affected unit and see what is up. Seems it will contain similar capacitors like the the ECU's.
PostPosted: Tue Feb 02, 2016 1:50 pm
^ Yep that was me, darn those caps.
PostPosted: Wed Feb 03, 2016 11:49 am
Yeah, I will be checking it out this weekend when I do the brakes.
