It is currently Mon Jun 03, 2024 8:23 pm
PostPosted: Fri Nov 20, 2015 10:20 am
Ok I'm having an issue with the launch studder on my colt.on my talon it worked fine. on my colt it's not working because the ecu doesn't see a vss or a change in movement. Always says 2 mph(if I remember correctly). I don't know where to start because it's cable driven transmission.
Does the cluster send the signal to the ecu saying the car is moving.I guessing that's how it works on the talons. Because They also have a cable from trans to cluster.
How does ecm/link see speed.I'm gonna guess the same way as jackal
Thanks for three help in advance
