Also, try a little search of Ebay. helped out a member posting on FB, who needed a set of front hubs in the 4x114.3 Seems they also made that same hub for the Accent in 1999 or something to that effect. Means it will be around for some time, or we can find it in the yards once again, very shortly.
I did a quick eBay search and came up with the following possible options. Could you take a quick peek and let me know if these look similar to what you found for the person you helped out on FB? I'm skeptical of the cheap price on the one option, but I want to first make sure the application will work. Plus, it saves Chris from digging around in the yard for me
http://www.ebay.com/itm/Front-Hub-Wheel ... 89&vxp=mtr
http://www.ebay.com/itm/FRONT-WHEEL-HUB ... fd&vxp=mtr
http://www.ebay.com/itm/FRONT-WHEEL-HUB ... 79&vxp=mtr
I really just need the hub since I've already pressed in a new bearing and seals in my Expo spindles. I'd rather go with new parts if possible, but wanted to get some feedback from those who've been down this road or are in the know about this. As always, thanks in advance for the help guys!
