Universal harness bar install and review http://www.4g61t.org/forum/viewtopic.php?f=22&t=38624 |
Author: | xxNocturnalxx [ Fri Feb 28, 2014 11:10 am ] |
Post subject: | Universal harness bar install and review |
http://www.frsport.com/Titanium-Color-H ... fgodV0MAGg http://nrgsuperstore.com/collections/in ... ation-list http://www.ebay.com/itm/47-52-5-Univers ... 75&vxp=mtr http://www.ebay.com/itm/170927119582?ss ... 1423.l2649 Based off of the rough measurements I have taken any of these bars could work with little to no customization. So I will be trying out one of these harness bars in anticipation of installing some nice aftermarket seats and ridding the auto seat beats. I will provide install pictures and review when the bar comes in. I understand one could probably be made for cheaper or whatever but for some of us who don't have a lot of time fuss around with customization or don't have the funds for a cage I think this could be an excellent alternative. |
Author: | CSM Shaun [ Fri Feb 28, 2014 11:42 am ] |
Post subject: | Re: Universal harness bar install and review |
Harness bar = good. These eBay universal harness bars = not so good. The metal on the "feet" of the bars, where the main bar would bolt to your chassis, looks really thin. The bendable joints at the "feet" that makes these "universal" are additional points of possible failure(s). I am guessing the two bars with heim joints at the ends are supposed to attach the main bar to other points of the chassis thus allowing the setup to have multiple points of contact with the chassis. Seems like a great idea but also introduces further points of possible failure. When I am trusting my life and possibly a passenger's life with a safety device it has to convince me that it is 110% safe. By all means give one of these a try but if it were me I would fabricate new "feet" from stronger material and weld each bendable joint solid once everything was bolted into place. Or bolt the sucker into place, strap into your 3,4,5,7 or whatever point harness then finish up by strapping your OE seat belt on. |
Author: | xxNocturnalxx [ Fri Feb 28, 2014 12:25 pm ] |
Obviously I'm not going to install some flimsy bar, and if it needs to be welded it will be. Hence this being a helpful review thread. |
Author: | coltdriver92 [ Sun Apr 13, 2014 12:21 pm ] |
Nice install! I was planning on getting one made but since the universal ones fit I'll just use the NRG one. I'm planning on getting a set of Corbeau FX1 Pro seats since they are around $700 for the set. Now just to figure out a clean way to mount the bar with the interior in. |
Author: | Mechacode [ Mon Apr 14, 2014 2:25 pm ] |
That looks like it'll do a good job of stiffening the ride up! |
Author: | xxNocturnalxx [ Mon Apr 14, 2014 2:30 pm ] |
Yes, and even more so if you want weld the upper adjustable joints. |
Author: | Mechacode [ Mon Apr 14, 2014 7:32 pm ] |
Or even connect it to the rear strut brace! |
