It is currently Sun Oct 19, 2025 6:24 pm
PostPosted: Sat Oct 08, 2005 12:03 pm
MITSUBISHI LANCER CB 1.6L DOHC (4G61 Engine) 1990-92 Engine Management System
ECM
The ECM is located behind the Left Hand Kick Panel.
ECM Voltage Table
1 to 24 Connector
Pin # Circuit and Status......................................... Voltage
1 Diagnostic Connector Fault Code Output
Terminal 1
Diagnostic Connector Grounded........................ Low volts
2 Diagnostic Connector Idle Speed Disable
Terminal 10
4 Oxygen Sensor Signal
Engine Warm
Engine Running.............................................. 0.2 to 0.8 Volts
Normal Signal................................................ 0.5 Volts Approx.
Normally fluctuates 7 to 8 times in 10 Seconds
5 Power Steering Switch
Ignition ON
Steering wheel at rest...................................... Battery volts
Steering wheel turned from rest position............ Low volts
6 Idle Switch
Ignition ON
Throttle at rest position.................................... Low volts
Throttle open................................................... Battery volts
7 A/C On Request Signal
Signal meets ON specifications........................ Low volts
Signal does not meet ON specifications............ 0 volts
8 Air Mass Meter
Air Charge Temperature Sensor Output
Ignition ON
Air Temperature @ 20° C
Engine Running............................................... 4 to 5 Volts
Voltage Output Decreases with Increase in Temperature.
10 Air Mass Meter Air Flow Sensor Output
Ignition ON...................................................... 5 volts
Engine Running.............................................. Digital Signal
Output Signal Increases in Frequency with Increase in Air Flow.
12 Spark Advance Disable Connector
Connector NOT Grounded................................ 5 volts
Connector Grounded........................................ Low volts
13 Fuel Pump Supply Volts Monitor
Fuel pump running........................................... Low volts
16 Air Mass Meter
Barometric Air Pressure Sensor Output
Ignition ON
BAP approximately 103 kPa (Sea level)............ 4 Volts Approx.
18 Vehicle Speed Sensor
Ignition ON...................................................... Low or 5 volts
Engine Running............................................... Digital Signal
5 volt square wave
Oscilloscope Pattern
19 Throttle Position Sensor Output Signal
Ignition ON
Throttle at rest................................................. 0.48 to 0.52 volts
Throttle fully open............................................ 4.8 to 5.2 volts
20 Engine Coolant Temperature Sensor
Ignition ON
Engine Cold.................................................... 2 to 3 volts
Engine Warm.................................................. Approx. 1 volt
21 Crank Angle Sensor
Engine Cranking or Running............................. Digital Signal
5 volt square wave
22 # 1 Cylinder TDC Sensor
5 volt square wave
23 ECM 5 Volt Output
24 Sensor Ground
Ignition ON / OFF............................................ 0 volts
51 to 68 Connector
51 Injector Ground
Ignition ON..................................................... Battery volts
52 Injector Ground
Ignition ON...................................................... Battery volts
54 Coil Switching Power Transistor
Engine cranking or running............................... Digital signal
55 Coil Switching Power Transistor
56 Control Relay Ground
Control relay energised.................................... Low volts
58 Idle Speed Control Motor
Engine running................................................ Low volt pulses
59 Idle Speed Control Motor
60 Injector Ground
61 Injector Ground
63 Control Relay Ground
64 Engine Checklight Ground
Engine Running
Engine Checklight OFF................................... Battery volts
65 A/C Relay Coil Ground
Relay energised.............................................. Low volts
66 Control Relay Ground
67 Idle Speed Control Motor
68 Idle Speed Control Motor
101 to 110 Connector
101 ECM Ground
102 ECM Supply Volts
Control relay energised..................................... Battery volts
103 ECM Supply Volts Permanent RAM Supply
Ignition ON / OFF............................................ Battery volts
104 ECM Ground
Manual Transmission
Ignition ON / OFF........................................... 0 volts
105 Oxygen Sensor Heater Ground
Heater ON....................................................... Low volts
Heater OFF..................................................... Battery volts
106 ECM Ground
107 Supply Volts for ECM / Sensors
108 Start Signal
Engine cranking............................................... Battery volts
109 Coil Switching Power Transistor
Engine running................................................ Digital signal
110 ECM Supply Volts
ECM
ECM Voltage Table
1 to 24 Connector
Terminal 1
Terminal 10
Engine Warm
Ignition ON
6 Idle Switch
Ignition ON
8 Air Mass Meter
Ignition ON
16 Air Mass Meter
Ignition ON
5 volt square wave
Ignition ON
Ignition ON
5 volt square wave
5 volt square wave
24 Sensor Ground
51 to 68 Connector
51 Injector Ground
52 Injector Ground
60 Injector Ground
61 Injector Ground
Engine Running
101 ECM Ground
104 ECM Ground
Manual Transmission
106 ECM Ground
108 Start Signal
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
