Ok, I am commenting on this because I was asked offline. I have nothing against anyone who has commented above, and definitely nothing against miragetec who is offering these parts (BTW I love your AWD car and do think this setup is NEEDED on your car along with matching front calipers).
This is an easy swap, and a really good price, but will definitely have a big, make that really really big change on brakes. (oh, one more small thing, the vacuum hose is in the wrong spot on the 3kgt booster, but this isnt a huge deal) Yes, I am running this exact setup on my rallycar, but I am also running 4 pot wilwoods on the front, and an adjustable brake bias valve for the rear.
http://geocities.com/colt4rally/assembl ... _4_eng.jpg
If you are running stock piston sizes in the front and rear, or even drums, then this setup will make your brakes really really touchy. How touchy, well, consider this...
A 7/8" m/c (master cyl, not mirage colt) will move all four pistons of your brakes with lets say 6 inches of pedal travel (8 is kind of arbitrary, but seems about right). There is obviously a mechanical advantage between the pedal and the m/c, but since the "pedal box" is staying the same, that advantage is staying the same. So, with that similarity in mind, consider the volume of fluid that was used to lock (or push the pedal down fully) the brakes. Volume of a cylinder = "pie" r^2 h (assuming h is travel of pedal). Then backward calculate the new travel with a 1-1/16 m/c. I get about 4". That means to lightly touch the brakes (which currently take about 1.5 - 2" will now be roughly 1-1.35".
So, with the above in mind for overall brakes just consider what your objective of this change is to be? Are your current brakes not locking up? If that's your problem, this probably isnt for you. Another point of reference is the wilwood.com website. They do a great job of describing bore size relative to force, but the clif notes are that bigger bore exerts less force at the caliper given the same input. So, going to a bigger m/c will actually make your braking worse (ask Berserko), but changing the booster to give a greater input force will get you comewhere back to where you are now. So, given some errors, you may or may not end up slightly better, or slightly worse than you currently are. I guess someone on this site could run the numbers with an estimation of input force, and the new input force created by an aggressive booster, but I dont have the time to figure it all out right now.
Also, if you think it takes too much pedal force to lock your brakes, then again, this probably isnt what you need. See the above reasoning.
On the other side, if your pedal goes to the floor and your car doesnt stop, well then you probably have a bad m/c or a bad caliper. Given that none of those are bad, then yes, you may need this bigger m/c.
Additionally, if you have bigger brake caliper area (either more cyl in your calipers, or bigger cyl) then this complete set it for you because you need to move more fluid to the calipers.
Just keep in mind that a 3200 pound eclipse with dual piston calipers doesnt even come with this big of an m/c?
So, that is my $.02, and probably isnt even worth that if you dont want to listen.
Chris
On another note.....what if you used the 3kgt booster with the stock m/c???? lots and lots of input force, same small volume, same pedal travel???
