It is currently Tue Jun 04, 2024 7:26 am
 Post subject: Big Brake Upgrade
PostPosted: Sun Dec 21, 2003 5:51 pm
I was thinking about Elantras and parts that work they suffer from the same captive rotor as we do. I found a big brake kit I believe will fit our colts.
http://www.precisionbrakes.com/brake-ki ... tions.html
325mmx22mm Front Discs!!! Probably need 17" rims to house those bad boys :)
PostPosted: Sun Dec 21, 2003 7:50 pm
That means those rotors are 12.75 inches in diameter. They might fit under 15" wheels. We would need to check with the dealer.
PostPosted: Sun Jan 11, 2004 11:07 am
Captive rotors are a real PITA. Compared to many other cars brakes though, the rotors on the mitsus are pretty hefty. thicker than most for the application. Most cars i see have rotors that are so thin that they warp easily(ford) or cant be turned at all. Read lousy heat dissipation. Besides you dont have to change rotors very often on a mitsu! I'm a cheapo but really think the Elantra discs would be a great upgrade for street use.
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
 Post subject: Re: Big Brake Upgrade
PostPosted: Sun Jan 11, 2004 11:59 am
I believe that's the company I tried to get to work me with and finally gave up after never getting a straight answer.
If you've got the bucks, it may be worth a shot, especially if they'll let you send them back.
