It is currently Mon Jun 03, 2024 7:36 pm
Post new topic  Reply to topic  [ 32 posts ]  Go to page 1 2 3 Next
PostPosted: Wed Feb 02, 2005 7:22 pm
:D OK Guys, the car has gone through yet another evolution and is at completion. Try and guess my HP and Torque to be shown on dyno. this FRI. My engine mods. are: 1st gen 4g63t motor
J&E alum. forged pistons(8.0 comp.;.02 ovrbr)
3angle valve job, OEM valves & springs
light porting and gasket match
EVOIII turbo, ceramic coated header
3" downpipe and exhaust
60mm on all intake and intercooler piping
custom FMIC (24x8x3)
stand alone eng. mgmt. (SDS)
750 injectors
HKS cams (264in and 272out)
balance shaft removed; underdrive pulleys;
prothane motor mounts; OEM rods, crank,
and bearings
PostPosted: Wed Feb 02, 2005 7:24 pm
What boost?
PostPosted: Wed Feb 02, 2005 9:17 pm
:-? Hard too say. we were using 20lbs, but it was just hitting too hard. I couldn't keep the boost down on my manual one, so we put in another. Twelve pounds seemed to work well. I plan to try my top pull @ 20 lbs., but who knows? Let's use 20 lbs. for base.
PostPosted: Wed Feb 02, 2005 9:35 pm
20psi? I will guess:
335whp and 330tq
89 Mirage turbo
92 laser awd
97 talon awd
08 Evo X
PostPosted: Wed Feb 02, 2005 11:48 pm
I put down 280/260ish on a B16G at 20psi with a starion, so I'll play it safe and say 310/300tq
PostPosted: Thu Feb 03, 2005 8:32 am
I'm thinking 350HP/320 TQ. I'd be curious to see because your motor sounds a lot like the motor I have with the only difference being that I have a little larger FMIC and I'm running FP2 cams.
PostPosted: Thu Feb 03, 2005 12:19 pm
my bro's colt dyno'd 315 and 330 tq at 22 psi and 104ish octane, the only difference is bill has sds, 750cc injectors and cams....
i am guessing 330 and 340 ish on pump gas at 18-20 psi and a little over 350hp at 24 psi on higher octane fuel.
is there any prize if we guess correctly?
PostPosted: Thu Feb 03, 2005 4:50 pm
A prize would be good. But what? It's not worth much, and I can be a cheap a---. I know, the closest one gets a beer at the Buscher Shootout. :lol:
UPDATE: time schedule is for 1200 EST. (Is that "High Noon"?)
PostPosted: Thu Feb 03, 2005 5:40 pm
Wish you woudl have said what kind of dyno ona msutange I would guess as high as a 350 on a Dynojet with the weather bring as it is 310.
Corey
90 C50 4G63 Swapped-Drag car
92 Eagle Talon Tsi AWD
96 Mitsu Eclipse GS-T
www.ongreenperformance.com
PostPosted: Fri Feb 04, 2005 6:12 pm
:) :-? :o Well, it's done. The bottom line is: Max POWER=288.4 @ 4.2K; Max TORQUE=306.5 @ 5.5K. I am verty satisfied. It was a Dynojet model dyno. I had numerous pulls to tune. Blew one tube(no T-bone clamp) several times. Full boost @3.8K. Boost over 12 lbs is a waste. The max pull was at 21 lbs., but the line was just going down. I plan to leave it at 12lbs. and go 20 at the track.
Question: although the HP number is dropping after 6K, would MPH still be increasing??
Results give a mixed impression. The set-up is great for street, which I want. I believe that it can run in the 12's. I know that I can tune closer to destruction, but why bother? My main bud, customtheColtgt, is livid. He say the machine lies. So now the motorheads are taking up a collection to buy a second opinion. Talk never ceases. Loving it. Bill
:oops: :oops: :oops: Duh! I goofed again. I got the RPM's switched. The max TORQUE was 306.5 @4.2K; the max POWER was 288.4 @5.5K.
At 6K, the power was about the same, but the torque had dropped. I can't remember the figures, but I worked out the formula given and at 6K the numbers worked out mathmatically. Well, the fund grows, so we may hit it again at a higher boost. Till then, I'm looking for Mar. 5, for test &tune at the track. :wink: Bill
PostPosted: Fri Feb 04, 2005 7:06 pm
BANNED FOR FRAUD
Well done Bill.
Jason Veraldi
Scammer
PostPosted: Fri Feb 04, 2005 7:46 pm
Yes, good results with an evo3 at 12 psi. But I'm perplexed as to why the power did not increase with higher boost. Boost leak, exhaust restriction, slipping clutch?
Anyway, you have a nice ride Bill, I hope to see it someday.
PostPosted: Fri Feb 04, 2005 8:18 pm
hmmm, yeah, your tube that was blowing might have also been leaking boost when it didn't blow off... but good numbers either way!
PostPosted: Fri Feb 04, 2005 8:34 pm
:o "After further review...." I notice that my air/fuel ratio was set right at 12.00. (Very rich.) I had thought that it would have been worked to 12.8 or 13.0, which is rich but within a more desireable mix. I may bump it later, but I will not go for another dyno. to get it. I'll try data logging. Any views on what changes can be made with a .8-1.0 leanout?? Oh, I used 93 pump gas.
PostPosted: Sat Feb 05, 2005 12:37 am
BANNED FOR FRAUD
On pump gas 12.0 for your afr is actually a good idea. You'd be surprised how close to a critically lean condition can come up by just a 2-3psi boost spike.
Jason Veraldi
Scammer
