Anyone?
I have been thinking of running these and a upgraded rear sway bar
http://www.ultraracingaustralia.com/page8.htm
FRONT FENDER BARS
As most of the vehicle’s front chassis over hanging is designated to carry the vertical loads from the front suspensions, it is vital that this part of the chassis is strong enough to take the bounce and rebound force of the suspension. Else, the effort of a good suspension will lose its meaning if the chassis absorbs all the forces from the suspension and not letting the suspension does what it suppose to do.
Therefore, these high quality 3-Point Fender Bars strengthen and reinforce these essential areas of your car and help maintain the suspension in position from all kind of vertical loads.
As a matter of fact, Fender Bars come as a standard feature on most of the high performance vehicles such as MITSUBISHI EVO and SUBARU WRX. Now, you can have the same feature on your car too!
Advantages of the fender bar:
Improve handling, stability at high speed and cornering, hence safer driving.
Provide a better braking and stopping performance.
Reduce NVH (Noise, Vibration and Harshness).
Increase stiffness of vehicle front chassis.
