| new Tach http://www.4g61t.org/forum/viewtopic.php?f=17&t=7630 |
| Author: | summitman [ Tue Feb 24, 2004 4:58 pm ] |
| Post subject: | new Tach |
hey guys today i finally got me a tached gauge cluster... it was from a automatic but it still serves its purpose and also looks good at the same time.... i hope to get some of them white face gauges that gage are producing to slap onto them.... |
| Author: | socrateez [ Tue Feb 24, 2004 10:07 pm ] |
| Post subject: | |
If i'm not mistaken, the 4g64 injectors are the same used in the 4g37, 210cc. If you use them, i would also use the associated MAS. Using the 4g15 MAS will make it way rich. With the 210cc injectors and MAS it will run a bit lean at idle and may surge a little when cold. Other than that, they will run fine. |
| Author: | {{|Jeff|}} [ Tue Feb 24, 2004 10:28 pm ] |
| Post subject: | |
are u sure the 4g64 injectors are the same i think that they are smaller then 210 i think 210cc only come out of the 4g37 engine and a 1.6L dohc NT engine. i am alos going to put these in my colt but i ported out my intake and used a 60 mm tb and a cold air intake. i hope it all runs smooth. -Jeff |
| Author: | Berserko [ Tue Feb 24, 2004 10:30 pm ] |
| Post subject: | |
I still have not added my 4g37 ecu with injectors its been too damn cold I'll lt you know how all the package works on the car. I also gotta change a drivers CV joint its mad clicking. |
| Author: | Berserko [ Tue Feb 24, 2004 10:45 pm ] |
| Post subject: | |
I think the 4g64 has 240cc injectors although I can't verify that for certain |
| Author: | summitman [ Tue Feb 24, 2004 11:33 pm ] |
| Post subject: | |
how do you tell their size? |
| Author: | socrateez [ Wed Feb 25, 2004 7:17 am ] |
| Post subject: | |
It'll have a series of numbers stamped on the sides. Las 3 digits are the size. |
