It is currently Tue Jun 04, 2024 7:03 am
 Post subject: headlight not working
PostPosted: Tue Jan 21, 2014 12:49 am
Guys can u help me pls about my headlight problem. Both headlight low and hi is not working. Any suggestion to solve this problem. Thanks in advance
My Feedback?
Asked
Bowdown
MattGSR
Coltsfan
Moulin13
Wrx110487
PostPosted: Tue Jan 21, 2014 11:03 pm
Page 8-96, 8-97 in the Electrical manual ...
PDF page 122 http://www.lilevo.com/mirage/89%20Colt% ... 0TURBO.pdf
There is a ground after the column switch for Low/High, and that will kill both headlamps output. Also, check the power in and out of the fuse 10A #6 and the headlight relay, likely underhood. Relay should have an open between two terminals and the other two should give you a resistance of like 70-80 ohms IIRC. If there is another identical relay nearby, or you have a spare, try swapping it in. If the relay fails, no power to either Low or High beam bulbs.
PostPosted: Fri Jan 24, 2014 8:07 am
Thanks sir
My Feedback?
Asked
Bowdown
MattGSR
Coltsfan
Moulin13
Wrx110487
