High rpm miss http://www.4g61t.org/forum/viewtopic.php?f=17&t=33759 |
Author: | geobass [ Sun Nov 14, 2010 2:11 pm ] |
Post subject: | High rpm miss |
History on this car: 1990 Dodge Colt GL Automatic 53,000 miles. Garage kept. Averaged about a thousand miles per year for the last 10 years. Bought this car Cheap because of a bad ECU. Things I have done since I bought the car. Cap, rotor, plugs,wires, fuel filter, and ecu. I have the same issue with a known good ECU. This car has a miss at higher rpm's. It runs great till approaching 50 miles an hour then I get the miss. Any thoughts will be greatly appreciated! George |
Author: | turboshawn [ Mon Nov 15, 2010 12:02 am ] |
Post subject: | Re: High rpm miss |
Check the boot of each spark plug and if you have any that are white or grey, you dont have a good tight connection. Sorry, its hard to trouble shoot a problem if your not there with the car!! So that's my guess. |
Author: | dan [ Mon Nov 15, 2010 2:08 pm ] |
I'd try a different MAF. |
Author: | geobass [ Sat Nov 27, 2010 11:32 am ] |
Quote: I'd try a different MAF.
That was it! Thanks Dan |
