It is currently Sun Apr 28, 2024 11:35 pm
PostPosted: Tue Oct 12, 2010 9:24 am
I have an 89 1.5L(X) and it is running very bad. Check engine light is on as expected.
I hooked up the TMO to find that:
* ECU ID is 1.8L – E019
* ECU Errors- there are 5 of them
12-Air Flow Sensor
13 Air Temp Sensor
15 Coolant Temp Sensor = (-62*)
25 Barometric Pressure Sensor = 1.24Bar
*Battery = 18.7v // Tested at Battery terminals = 13.6Vdc
*TPS = 100%
*O2 Sensor = 4.98Vdc
Okay, so likely someone tossed a 1.8L ECU in to get it to run, when I get home tonight I will pull the panel to see what I have.
I do have a ECU from a 94 1.5L(A), is it possible to swap some pins at the ECU and use it or do I have to purchase one of the 1.5L(X) ECUs avialable.
According to the list at the link I am posting there are other versions/model numbers available.
This could be very useful in the future check it out:
http://missourimitsu.com/ar/t2105.htm
Thanks,
Joe
89 Colt GT 1.5 auto- conversion 4g63t 5-spd, L2A...
89 Colt GT 1.6 5spd- donor
92 VR4 32/1000 SOLD
PostPosted: Tue Oct 12, 2010 10:20 am
The 94 ecu will not work because they do not use a maf sensor like the 3g's do. You will need an ecu from a 89-92 csm with the 1.5L engine. I have a few for cheap in my FS thread but I have no idea if they are good or not because I have no way to test them.
If the 1.8L ecu is good and its from a 90-94 dsm check to see if you have the matching injectors and maf as someone may have upgraded. Then again your car is a 89 model so that is unlikely.
PostPosted: Tue Oct 12, 2010 12:11 pm
I looked at your FS listing and will take the required ECUs to piece a good one together; as mentioned in the add.
Also what is the MDxxxxx number on the ECU case, I want to cross reference it to the 89 as well.
If I can make it work please provide a quote to 53128.
Thanks,
Joe
92 VR4 32/1000 SOLD
PostPosted: Sun Oct 17, 2010 11:43 am
Thanks for the quick shipping, this is just what I needed.
92 VR4 32/1000 SOLD
PostPosted: Sun Oct 17, 2010 4:23 pm
Let me know if you have any other issues, I have some spare Colt parts up this way! ;)
-Shawn
MEMBER #1495
'92 Dodge Colt 63 swap (SOLD)
'92 Galant VR-4 (it's Alive!!)
'12 Forester (DD)
GONE:
'92 Plymouth Colt 12v 4M->5M
'90 Dodge Colt GL 8v 3A
'89 Plymouth Colt 8v 5M
'92 Galant LS
'92 Galant GSR
'93 Galant LS
'93 Galant S
