What size are the rotors on the front of a 1.5L hatch?? Also what size are they on the turbo? When I was trying to find turbo caliper, the interchange also gave me the caliper's from a 89 galant? Can this be right, if it is, are the rotors from the galant the same?
p.s. If the calipers are the same, then are the caliper brackets the same as well
I am not sure about the size of the rotor, but I do know that the last of the 92 built Colts and Summits, the rotors are vented instead of solid in front...also, I have compared the Galant and Summit calipers and they seem identical, just the Galant ones are bigger in places. I used Galant brake pads in my Summit calipers, but they needed a bit of grinding (along the top of the pad, where it hits the caliper. They were a shave too big, almost enough to wedge them in though.) I am basing my knowledge on comparasin of Galant to Summit 1.5, so perhaps the GT turbo caliper is the same as the Galant one.
