So what happened was, I was driving and shut off my car and then it would not start. I came back a few hours later and she fired right up. It tried to start but just wouldn't go. Got almost home and it died on me while driving. Came back in a little bit and she fired right up. Then it happened twice more lol, I took a friend home and it died on the way back. I walked the 4 miles home then went back for the car a few days later. Then on the way home with the car it died AGAIN! So we put a chain on it and pulled it the rest of the way home. Each time it shut off, it did it sooner then before. Is this characteristic of the ECU or could it be the distributor?
Thank you for your guys time. I am going to pull the ECU out tomorrow to have a look at it, But I don't have another one to see if its the problem for sure or not. I don't have a lot of money to put into the car, I just had the top end rebuilt a month ago and now this happens. I'm going to check the ECU for leaking caps. I really need my car going by Jan 7th, I have to drive 450 miles round trip. I really appreciate the help.
I also had the same issues with corroded battery cables. mpi relay, or bad fuel pump can also be the cause. but yea most likely its the engine computer.
