ok yesterday i tryed to start my can i pulled the plugs and oiled the cyclenders and nothing so we sprayed fuel in the intake mani and it started and smoked like crazy then stoped so i drained the tank and put new gas into it the old gas stank like you would not beleave like paint thinner anyway still wouldnt start so i pulled the gas lines off at the filter and made sure the harnes was connected in the hole under the back seat and still nothing so i took the fuel line off at the filter and bone dry no gas
my qushtion is a fuel pump ?
anyone else ever had this problem is it eletrical of just the fuel pump?
also is there any upgrades regaurding fuel pumps? with out messing with the lines or injectors and redoing the whole system with new or custom stuff i just want it to start and stay running
just read something about the caps on the ecu drying out the car sat for 3 years on the doors its cracked from the sun and heat and were not like that before and im having the same problem no sound at the pump nothing
