| Motor mounts swapping 4g63t into 1.5 chassis http://www.4g61t.org/forum/viewtopic.php?f=17&t=21425 |
| Author: | bartels903 [ Sun May 27, 2007 12:17 am ] |
| Post subject: | Motor mounts swapping 4g63t into 1.5 chassis |
Well, I am planning out my 4g63 swap into my 1.5l chassis. I have the timing belt mount from my 1g, and I looked at pictures of the 92-95 elantra mount side by side with the 1g timing belt mount, and they looked nearly the same. Could I use my 1g mount with a little trimming? |
| Author: | Jeremy Rothrock [ Sun May 27, 2007 12:27 am ] |
| Post subject: | |
No it won't work without serious modification. Where it bolts to the body lies the problem. |
| Author: | bartels903 [ Sun May 27, 2007 12:35 am ] |
| Post subject: | |
Alright, Is there any other cars besides the 92-95 mirage that they can come off of? Im going to the junkyard tomorrow, so I figure I will ask. |
| Author: | kenc15 [ Sun May 27, 2007 6:06 am ] |
| Post subject: | |
the 92-95 elantra is your only bet, junkyards usually have elantra. other than the elantra you can go buy a 89 mirage mount |
| Author: | dsmdizzle [ Wed May 30, 2007 12:01 am ] |
| Post subject: | |
I found a good reference for the pics of the exact mounts that you need. So here you go. Go to the bottom. http://forum.4g61t.org/viewtopic.php?hi ... or&t=20704 |
| Author: | Koby [ Tue Jul 03, 2007 3:07 pm ] |
| Post subject: | |
I really want to see what the clear answer to this is. I've searched and read about 100 different ones. 1.5L 4th gen chassis 1g motor/trans are you going to need all the mounts out of an elantra? :-/ I've heard too many answers and just want to get it straight. |
| Author: | pma1123 [ Tue Jul 03, 2007 3:30 pm ] |
| Post subject: | |
92-95 dohc 1.8L elantra OR 89 turbo mirage OR 1.6L NA csm sedan mounts. Slim chances of finding the latter of the two. |
| Author: | Flying Eagle [ Tue Jul 03, 2007 8:59 pm ] |
| Post subject: | |
4th gen chassis - meaning 93+ bodystyle? |
| Author: | Aaron_37 [ Wed Jul 04, 2007 12:57 am ] |
| Post subject: | |
If that's what he/she means, then they're sadly mistaken... we 4g's must unfortunately seek the Elantra/Turbo mount too. |
