It is currently Fri Oct 24, 2025 8:16 pm
PostPosted: Wed Oct 20, 2004 2:47 pm
Im leaking oil like a siv from behind the crank pulley. Im pretty sure that it is the oil seal. For you guys that have done this, whats the easiest/quickest way of doing it?
thanks
PostPosted: Wed Oct 20, 2004 5:37 pm
easiest/quickest
Get a factory service manual for your car and follow the directions to remove the transmission. Once the tranny is out you'll have to remove either the flywheel (manual) or flex plate (automatic). You might be able to get the old seal out of its carrier without removing the carrier from the back of the block. If so, drive a new seal into place. Use a seal driver so that you don't bend your new seal. If you have to remove the carrier to get the old seal out you'll need to remove a few of the oil pan bolts and may very well bugger up the oil pan gasket - be prepared for that. Change the oil seals where the axle halfshafts plug into the tranny while you have the axles out.
Personally, I'd pull the engine and tranny out of the chassis and do the job on a bench (or engine stand). You can change the front seal, oil pump seal, timing belt & tensioner, other belts AND do a very thorough cleaning of the engine bay and the engine itself.
Phil Hutchinson
1986 G15B, 1986 G32B, 1988 G32B
PostPosted: Wed Oct 20, 2004 5:45 pm
didnt he say crank pulley?? on the drivers side??
1987 Dodge colt premier 4 door g32bt running!!!! 3speed automatics suck!
PostPosted: Wed Oct 20, 2004 8:26 pm
i ...DID....
regardless, i dont want to pull the engine (drop 2 mounts worst case scenario)
... you see this is my beater, the only thing i want to keep from happening is a huge puddle on my driveway everytime i stop and the money spent on the oil to top it off :lol:
anybody else?
PostPosted: Wed Oct 20, 2004 10:31 pm
You should be able to get to it pretty easy. Pull the driver side wheel and pull the pully and covers. Everything is right there. Thats the beauty of the 4g15, everything is easy to get to! :wink:
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Wed Oct 20, 2004 11:35 pm
what about on a 4g63t? is it just as easy? I have the same problem.
PostPosted: Thu Oct 21, 2004 1:44 am
I did mine on my 4g15, EASY!! If you don't know what you're getting into, definatly get a manual first. You're going to have to make sure everything is in time when you put it back together, very important. Also, one little tip; put the seal in the freezer, it will shrink and allow you to slide it right in(most of the time), or atleast make it a lot easier.
1989 Mirage Turbo 4g63T w/ small 16g just bolted in so far.
LSD, 1g flywheel/clutch.
1989 Colt GT 4g61T (63T build in progress)
1g ECU, Injectors, Exhaust manifold, 16g evo III Turbo, SMIC, and C Exhaust cam -9*
K&N Air filter, airbox cut up, MSD plug wires, NGKs, Apexi S-AFC II, MAF translator, tubular o2 housing w/ dump tube, Full 3" mandral.
Now I ran out of fuel!!
PostPosted: Thu Oct 21, 2004 8:00 am
did you still need the seal driver to put the new one in using that freezer trick?
As far as manual goes, i have acces to one online, however say i want a printed one, which manual do you guys most commonly use? I have a colt 100 fwd, and my local parts guys dont have one in stock. Where did you guys buy yours from, and for what specific car?
thanks
PostPosted: Thu Oct 21, 2004 3:10 pm
My bad. What was I thinking?
Phil Hutchinson
