| Injector upgrade http://www.4g61t.org/forum/viewtopic.php?f=17&t=11146 |
| Author: | akdriverjd [ Tue Oct 12, 2004 2:38 am ] |
| Post subject: | Injector upgrade |
On VFAQ, it says a "210cc injector upgrade, a 4g67 ECU upgrade and a 4g67 MAF(? Mass airflow meter?) upgrade will give an overall increase in power" True? How hard to do? Need a bigger/better fuel management system? Hit me back *glances at socrateez* |
| Author: | DarkHorse [ Tue Oct 12, 2004 2:57 am ] |
| Post subject: | |
you mean 4g37, not 67. talk to Tim from ottowa, a.k.a. flying eagle he has done this recently and documented all of his trials and tribulations. ~joe |
| Author: | socrateez [ Tue Oct 12, 2004 9:26 am ] |
| Post subject: | |
I'm running everything except the ecu. The throttlebody with porting gains you the biggest benefit. The MAS has the other bypass hole opened so you get better airflow through the intake system. With the addition of more unmetered air, you have a serious lean issue. Thats where the 210cc injectors come in! |
| Author: | akdriverjd [ Tue Oct 12, 2004 6:39 pm ] |
| Post subject: | |
Right on, thanks. |
