It is currently Fri Oct 24, 2025 3:51 am
Post new topic  Reply to topic  [ 119 posts ]  Go to page Previous 1 2 3 4 58 Next
PostPosted: Mon Aug 04, 2003 9:28 pm
Colt-r, that dyno plot was generated artificially correct? If not I'd like to see the 4G15 that revs to 10k rpm! :o
Yeah its a simulation. No you cant rev one to 10k. :( The sim just generates data until data points go to zero. You have to already have an idea of the useful rpm range. I could have instructed it to cut off at say 8k or 5k. The sim isnt an exact Dyno result, its dependent on the information supplied by the user. Some educated guess work is involved. The software creator claims accuracy to 5%.
If anyone has all the engine specs for the 4g15 8 and 12 valve engines, i could make a pretty accurate dyno spec. I need cam lift, combustion chamber volumes, intake and exhaust timing events, flow data(not as neccessary)etc.etc. The software makes its own guesses on cam profiles and such. It gets in the ball park but could me more accurate. My cheesy hanes manual barely tells tune up specs. :(
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Mon Aug 04, 2003 9:40 pm
Hey VWDSMGUY, Did your '89 Mirage have the 4G63 or 4G61 engine. Damn good for G63, but much more for G61.
PostPosted: Mon Aug 04, 2003 10:50 pm
There's no combustion chamber volumes or cam lift specs in the factory manuals, but here's something at least.
1987 12v:
Intake
Open: 18 deg. BTDC
Close: 49 deg. ABDC
Duration: 247 deg.
Exhaust
Open: 49 deg. BBDC
Close: 18 deg. ATDC
Duration: 247 deg.
Overlap: 36 deg.
1989 8v:
Intake
Open: 18.5 deg. BTDC
Close: 51.5 deg. ABDC
Duration: 250 deg.
Exhaust
Open: 51.5 deg. BBDC
Close: 18.5 deg. ATDC
Duration: 250 deg.
Overlap: 37 deg.
Witty Signature Goes Here!
PostPosted: Tue Aug 05, 2003 3:53 am
Ah, ok - I think I have that program somewhere. Is it something like "Wotchimacallit Dyno 2000"???
PostPosted: Tue Aug 05, 2003 6:38 am
kjmerkel69... thanx man!
The softwares name is Desktop dyno 2000. I would like to find copys of similar software if anyone knows where to find them. :wink:
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Wed Aug 27, 2003 9:35 pm
Been running with 9* retard on the cam timing for awhile now. No noticeable difference in mileage. I think about 5* retard would be preferable. Without a adjustable cam gear though, 9* is better than stock! Bottom end suffers a little but having this little motor pull hard to redline is great! Power peaks about 6800rpm. 5* timing should shift the powerband back a little. I generally shift out of gears at higher rpm now due to the new power band. Takes getting used to. Car is definately faster though. Anyone else try this please post and let me know their results.
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Wed Aug 27, 2003 11:51 pm
I wanna do this to my 4g15b but Im not too sure exactly how to do it. How much do I have to adjust?
PostPosted: Thu Aug 28, 2003 1:45 am
4g61t Delinquent
just one tooth
I own a CSM.
PostPosted: Thu Aug 28, 2003 4:26 am
I'm going to do this, but might change the cam belt at the same time (got 20kmiles on it). I got a spare cam pulley from scrap(junk) yard, I'm going to drill a new hole for the little dowel pin thing. I'll put it opposite the old one, and make it about 5 degrees retard.
The green bit on this picture should be the right place I think for retarded camshaft.http://members.madasafish.com/~pumaproton/cam/
Can someone just confirm that I have it in the right place, I don't want to ruin it all :) I'll draw it a lot neater and do it on a pillar drill.
PostPosted: Thu Aug 28, 2003 6:16 am
good idea! I'm gonna look around work for a cam gear.
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Sat Aug 30, 2003 6:47 pm
Intake manifold pictures.
http://camzr4.orcon.net.nz/Manifold%20all%20welded.jpg
http://camzr4.orcon.net.nz/Manifold%20Inside.jpg
This is the manifold I have made for my 4G63 Lancer.
It hasn't been installed as yet, but will be dynoed once it has been (in a month or so)
PostPosted: Mon Sep 01, 2003 5:58 pm
I just installed my modified cam pulley. Its amazing now, car pulls really hard all the way with no noticable drop in power on the bottom of the rev range either. I set mine to about 5 degrees.
Photos
It's been the best modification I've done so far.
Really need that weber and exhaust headers now :)[/url]
PostPosted: Mon Sep 01, 2003 6:32 pm
Really does bring it alive doesnt it? :D Thanx for the pics and diagram pumaproton! As soon as i get a another cam gear or a nice weekend, i'm drilling mine! I was looking at the 8valve cam gear and its a cast piece, not stamped steel like ours. Looks as though you could put it on backwards. If it is, i suppose you would have a dual purpose cam. Switch it around for 5* advance. hmm.
Doesnt appear on simulator though that advanceing would gain much benefit.
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Tue Sep 02, 2003 5:46 am
I didn't know 8 valves have got cast cam pulleys.
I changed mine by taking off the plastic cam cover and sliding off the old and sliding in the new. Took about 10 minutes, checking about 10 times I got it lined up all right :) Didn't want to knock the piston to a valve.
One interestting thing is, it seems to sound different, more like a sports car but it may be that I'm sitting higher up in the rev range so often.
PostPosted: Sun Sep 07, 2003 4:42 pm
forgive me if my blind ass missed a post in this topic but can the same mod be done to the 8 valve??? of am i sh*t out of luck
www.lowmotion.org
