For anyone else out there that has mushroomed the ball joint studs trying to remove them, heres the solution.
1. (Proper way) Use a pickle fork. (looks kind of like a tuning fork)
2. Hit the knuckle where the stud inserts with a fairly sized hammer. Afew good blows and the stud will pop out.
I dismantle cars for a living and method two is the easiest and doesnt tear the rubber on the ball joint.
looking forward to your write up Schooled1.
Socrateez, I've done it that way & I've ruined every boot on the car with the fork.
In the factory service manual, they illustrate a special tool for removing Tie Rod Ends & Ball Joints. you can probibly get it from $Satan$, or miller special tool for an arm & a leg, but I got mine here
http://www.mytoolstore.com/toolaid/suspn02.html
for $13.50 & it does the job great!
