I have a 86 mirage gatchback for sale.
Black, body is ok, no huge damage, but its hit its share of cones and shopping carts.
Gutted interior. blue rollbar that was scca compliant until it needed a cross bar. Should be super easy to add the bar and get the car recert.
Has remote resvior fox shocks/struts. Fronts are coil over, and adjustable
custom sway bars front and rear. With heim joint end links. They are getting a bit loose and starting to get a bit noisy.
Adjustable prop valve
Fuel safe fuel cell
Battery kill switch
Gauges, oil pressure, water temp and boost. Also has digital wideband read out.
1.6 liter engine, factory turbo, rebuilt. New t-belt, pump, tuneup ect.
Tuned on megasquirtII to 20PSI with water meth injection, closed loop idle control, wideband ect.
Factory 5 speed, 5th gear works, 5th gear control box removed and bypassed. so you put it in 5th, it goes in 5th.
New clutch, wheel bearings ect
front mount IC from turbo mx6 and custom plumbing.
Really alot to list, I'm sure i'm leaving some out.
It has only 1 wiper arm for the driver
missing left front turn signal. I think i have it, just need to find it.
Drivers seat tore up pretty good.
No interior.
Its been a racecar, so its not perfect
Runs and drives pretty darn good. I have returned it to street car use sorta and have comuted 30miles each way everyday for the last few months. Been a great car.
I have alot spares to go with it for the asking price. Extra wheels, tires, wing, hubs, maf and ECU, 2 transmissions, starters, alternators misc bits and peices, the factory mitsubishi hub service tools for swapping rotors/wheel bearings, race brake pads and a bunch more.
$4000 In Vancouver WA. just north of portland.
As the IC plumbing was being built
