rear end ratios for AWD cars http://www.4g61t.org/forum/viewtopic.php?f=100&t=39403 |
Author: | lancerman [ Fri Dec 19, 2014 12:17 am ] |
Post subject: | rear end ratios for AWD cars |
just want to make a post to clarify something that is missing from these forums. for DSM cars the 5 speed AWD had 3.54 and A/T cars had a 3.3 rear. its a little different for the wagons. there were two engines mated to AWD wagons. 1.8L and 2.4L so there are actually three different rear end ratios. 1.8 AWD 5speed had a 3.9 rear end. 1.8 AWD A/T had a 3.54 rear end. 2.4 AWD 5 speed has a 3.54 rear end. 2.4 AWD A/T had the 3.3 rear end. I confirmed this info with ring and pinion part numbers and replacemnt transmissions. whats cool about this is if someone wanted to build a quick around town AWD AUTO car you can use the ring and pinion form the 1.8 AWD A/T trans and install it in the turbo trans and use the 3.54 rear end. So if anyone happens to have an auto AWD trans that had the 3.54 rear end i would like to find one so i can use the ring and pinion from it. this coolness also applies to the 5 speed cars. i daily drive an evo 1 with the 3.9 rear. I have never been tempted to swap to USA 3.54 parts. if i was going to build a 5speed wagon i would most certainly use the 3.9 rear and evo 1-3 transmission. I was getting the impression everyone thinks if their car is AWD it must have the 2.4. when some have actually had the 1.8L. the engines look the same. http://www.automobile-catalog.com/make/ ... /1992.html |
Author: | CaptainTonus [ Fri Dec 19, 2014 12:54 am ] |
Post subject: | Re: rear end ratios for AWD cars |
Nice to see you back on here, Jerry! That's great info. Thanks for sharing. I always thought the 3.9 diff wouldn't work with US rear axles in a DSM. Any truth to that? |
Author: | 89Mirageman [ Fri Dec 19, 2014 8:53 am ] |
The 1.8 wagons with AWD seemed to be even more rare. I know Trevtec had one at one time but he hasn't been on in quite a while. |
Author: | lancerman [ Fri Dec 19, 2014 10:37 am ] |
I am searching for a clean Expo for my next build. will happen this year. pretty exited about it. the 1.8 AWD was only on 92 cars. maybe they didnt sell well? for changing rear diff ratios its always easiest to just switch the ring and pinion. every outer case is different for AWD cars. 1G, 2G, evo 1-3, evo 4-8, and expo all have different cases but interchangable R&P. . |
Author: | CaptainTonus [ Fri Dec 19, 2014 10:51 am ] |
Quote: for changing rear diff ratios its always easiest to just switch the ring and pinion. every outer case is different for AWD cars. 1G, 2G, evo 1-3, evo 4-8, and expo all have different cases but interchangable R&P. .
That's what I figured. I'd love to do that with my DSM, I hate the long gearing. I feel like it'd be tough with an auto because you only have 4 gears, and I know the drag racing guys try as hard as possible to not shift into 4th in the 1/4-mile, but I guess it depends on what you want to do with the car.
Author: | lancerman [ Fri Dec 19, 2014 11:49 am ] |
I have never liked auto setups that dont use forth. some guys actually do. most put an extra heavy, extra tall tire on the car so they dont need 4th. the extra tall gearing makes it flat boring for a daily... I just plan to reduce boost for 4th gear pulls.. not many oppurtunties to go over 100mph anyways driving the way I do.. |
Author: | 89Mirageman [ Fri Dec 19, 2014 11:56 am ] |
Still surprised someone hasn't just put a 1g awd rear end in a fwd wagon. I mean I know they come awd already but are kinda hard to find. Seems lately even the fwd ones are getting rare. |
Author: | Natedog [ Fri Dec 19, 2014 3:33 pm ] |
Thats a good looking Evo. What are ya wanting for it? ![]() |
Author: | CaptainTonus [ Fri Dec 19, 2014 5:45 pm ] |
I'm the biggest jellyfish in the ocean right now. |
