I now own a Turbo Colt/Mirage, what should I inspect ??? http://www.4g61t.org/forum/viewtopic.php?f=10&t=5831 |
Author: | Guest [ Tue Oct 21, 2003 8:42 am ] |
Post subject: | I now own a Turbo Colt/Mirage, what should I inspect ??? |
Here's a list of things that need to be changed right away. These aren't optional. Ignoring these items will definitely leave you stranded one day. The timing belt - Unless you have a record of it being changed recently, change it now. The ECU Capacitors - Again, unless you know they've been changed, you really need to change them. The cost of changing them is like 1/100 of buying a replacement ecu. Things that are a good idea to replace. Items marked with a * can be replaced with upgraded parts. - Spark Plugs - Spark Plug Wires * - Fuel Filter - Air Filter * - BISS O-ring - tranny fluid - engine oil - radiator fluid - tie rod ends - ball joints - wheel bearings - all rubber parts (hoses, bushings) |
Author: | Guest [ Tue Oct 21, 2003 8:48 am ] |
Post subject: | |
Guys add to this list. I want to stick this into the archives. |
Author: | PaulMezz [ Tue Oct 21, 2003 9:16 am ] |
Post subject: | |
Don't forget to change the oil in both the engine and tranny. Coolant is a good idea too. As with any car, check the steering/suspension too.
It doesn't hurt to replace things to get it all at a known state (well, it can hurt the wallet and sometimes the knuckles ![]() -paul |
Author: | Crackerman [ Tue Oct 21, 2003 11:12 am ] |
Post subject: | |
don't forget safety items, brakes, brake lines for cracks, change brake fluid if it is black/dark grey, should be almost clear, headlights/tailights/brake lights |
Author: | netninja2001 [ Tue Oct 21, 2003 2:42 pm ] |
Post subject: | |
Since I'm getting my engine from a junkyard, I'll be replacing: - all the gaskets in the engine - while im in there, checking all the valves and pistons for damage - compression test the cylinders - check out the turbo for rubbing/damage/play - replace accesory belt while replacing timing belt |
Author: | 89 mirage evo [ Tue Oct 21, 2003 10:50 pm ] |
Post subject: | |
i think a leakdown test is more accurate than a compression test. lets you know if either an exhaust valve, intake valve, or rings are bad. dont forget the balance shaft belt when you do your timing belt. or just install a eliminator kit |
Author: | m435tro [ Wed Oct 22, 2003 7:42 am ] |
Post subject: | |
Quote: don't forget safety items...
..also get Fire Extinguisher. It wont cost that much to keep one in your GT.
