It is currently Fri May 17, 2024 10:05 pm
PostPosted: Sun Feb 23, 2003 2:48 am
Well I have had the GC Coilovers on my setup long enough now I can make some comments on them now. Note these only are in regards to being a daily driver I haven't been to the AutoX course or track so I cannot comment there...
Recomended String Rates/Lengths
Front 300lbs/inch 7"
Rear 250lbs/inch 7"
If you use these springs and have the collars at the top you can acheive stock ride height
I recommend the use of Koni Yellows I find the KYB GR2's can be somewhat bouncy I assume its due to the high spring rate. Also not if you are using GR2's the strut body is physically smaller than the AGX body (which my kit was built around) A good way to file this space is but cutting a rubber mouse pad to size and wrappring it around the strut body it keeps the collar in place and keeps noise to a minimum... :) I am going to do a VFAQ on this ral pictures and the Diaglog on the talon VFAQ is deceiving and I will correct the text to make it more clear (If you read it the way I did you get VERY noisy front coilovers).
Driveability
Its very firm but not harsh so if you looking to ride on a cloud like you would in a Cadilac or similar vechicle forget it this is NOT for you. But you could drive the car a couple hundred miles get out and not be totally crippled... It seems going over train tracks is very good (with cut bump stops) it doesn't bottom out.
Current Settings
I currently have the fronts on full soft (I just put them on the car recently and have tuned them up yet.)
I currently have the rears set for 1/2 turn from full soft.
I have the fronts at the top of the collars (although I only have 6" springs this nets me about 1" of lowering. Rear collars are set at about 7 threads from the top (7/8" of lowering in the rear) It looks great corners very squarely only a small bit of understeer. Very sporty feel. As for noise from the coilovers there is none (The only time you get noise from coilovers is if you use cheap ones or they are installed in-correctly or have bad rear top hat seals like I had.) I had to buy some replacemnt rear top hats seals and rear sleeves from Tony @ GC and he was more than helpful in getting me all the parts I needed to convert the set from KYB AGX compatible to Koni Yellow (their perces differ there for you need new rear sleeves)
Hope this helps..
PostPosted: Sun Feb 23, 2003 4:46 pm
What shocks are you using again? THe AGX's or the Konis? I have been a bad man and not read all the threads :). I am DEFINITELY in the market for a replacement suspension setup as mine is ASS :(:(:(. Stock colt shocks, Eibach Sportlines (2" drop on a talon, 3" on the colt thanks to the lower perch), and BIG front swaybar. Understeer mania, bouncy bouncy too :(.
Good info for sure! Archive material!
PostPosted: Sun Feb 23, 2003 5:11 pm
Broke:
Koni Yellows
with GC Coilover 300lbs/f 250lbs/r
PostPosted: Mon Feb 24, 2003 12:01 am
Berserko: are you suggesting GR2's would be bouncy using any lowering
spring, as they are all stiffer than stock?
Broke4speed: What drop would I get using sportlines with colt specific
GR2's(front)?
'89 Plymouth 200GT 4g61t , evo316g, fmic, 1g cams, cyclone intake, 1g throttle body, 2.5 hard pipes, 190 walboro, 650's, 2g o2, 2g ex mani,3" mandrel, ACT 2100, Fidenza flywheel, Unorthodox underdrive pulley, SBR lsd, , AEM wideband, tuned by maf-t, 2" drop, gr-2's, brembo
cross-drilled, metal masters, 205-50 Falken Azenis, etc., 280 whp @ 256 tq
PostPosted: Mon Feb 24, 2003 4:48 am
Nodents:
Not at all I ran Eibach sportlines on GR2s they were fine the GR2s didn't like 300lb springs they seemed bouncy with stock or the eibachs there were great.... As for drop expect 2"-2.5" in the front (the back is not so bad if you use FWD springs) BUT if you use Talon GR2s up front you raise the front end up about 3/4" of an inch the car so the car will be more level and the drop to be a bit more subtle...
PostPosted: Mon Feb 24, 2003 6:47 am
GR2's(front)?
Berzerko is right, but my drop is closer to the 2.5 mark, maybe a bit more :o . I am bouncing off the uncut bumpstops (d'oh, forgot to cut them). The springs I am using are the talon FWD ones, they fit too.
PostPosted: Mon Feb 24, 2003 10:52 am
Thanx for the info guys. :D It seems that for an approximately 1.5" drop, I'll need to go with the sportlines and talon GR2's. 8)
